ModSyslogUI v1.1.0 [28-Feb-2026] - add-on providing System Log page UI filtering capabilities
This could lead to problems later on because the current update process downloads the new files, but then continues running the “old” script to do the install, instead of invoking the new scrip
Which is easily fixed @kstamand : just run
exec /path/to/script
after the update routine.
Thanks for the pointer, I didn’t know how to accomplish what @jksmurf was asking. Would using >> exec "$0" "$@" << after the update accomplish the same thing?
Yes, amtm does a similar thing, exec spawns a new shell.
Just went in to amtm to check and it is indeed in the menu, so well done to you and thank you again! I really like the simplicity and it seems a few others (with scribe/uscribe) do too.
I did the update from the 'ms' menu there, but it still bugs me (as above, OCD much...?) that the version shows the same before and after you select update in the menu and does not change until after you exit the addon and and go back in again.
And now, a small equest... a number of addons have auto-update... no hurry but I like that feature ... and I cannot see it being a system-breaker here even if it does not go to plan.
v1.0.3 will properly display the version after an update, but I will wait a few days to see if there are any other simple update requests to include (I already have @maghuro update included).
Regarding auto-update, are you referring to from within amtm using the "u" option or something else? If from amtm, I believe the script has the proper setup for that already, but I welcome others feedback to help educate me further.
amtm does not provide an auto-update feature as there is no common update logic for the various scripts it supports. Rather, some of the scripts themselves have such an option.
For example, one can enable the auto update function in MerlinAU.
@kstamand wait with a script specific autoupdate function, I got something better cooking.
v1.0.1 (26-Jan-2026)
- Added: Supported firmware version check (3004.388.* and 3006.102.* only)
- Updated: Changed install completion verbiage, noting that editing logFilter.json is optional
- Added: Added a call to show the Menu at completion of install, instead of exiting the script
- Updated: Changed insert point for custom php code (UI filter option) so it will work with either 3004.388.* or 3006.102.*
Update to address code logic that adds the filtering option to the System Log page, allowing it to work with either firmware versions 3004.388.* or 3006.102.*.
Would appreciate if some with 3004.388.* firmware installed reply back here if it works and if not, provide any information that might help me debug.
Hello,
I installed your addon on my RT-AX86U running firmware 3004.388.11 without any issue.
I did some test and was able to filter the logs. I need to look deeper but it looks like very promising, great work!
May I suggest one thing: Could you update the original post?
You mentioned firmware 3006 and few router models but you didn't include/update this first post with v1.0.1 (26-Jan-2026) and 3004.388.* firmware support.
I had to read all pages and reached page #3 to see the v1.0.1's information.
Not really a big deal, just easier for the reader.
Again, great job, very interesting.
So, is this a good time to drop scribe? Will it work okay with a remote syslog server?
Hello,
Thanks for the feedback and I have updated post #1
Dropping scribe is a personal choice. Personally, (I'm biased / I know) I prefer the "lightweight" nature of this script and especially the updated capabilities I'm working on (teaser - presets support (add, delete, edit), enhanced help information (non-intrusive), and possibly expanded filtering expression support)
Hello,
I had to uninstall the module because it was not working anymore on my RT-AX86U, even if it running on the same firmware version as for installation. (no change since then)
First, I tried to disable/enable module (with and without logoff/login from admin web interface). Then, I tried to uninstall and install again, still no luck.
My test was to exclude everything with "blocked" (my first try was kernel: [BLOCKED - INBOUND]``, but reduce progressively to only test with one word "Blocked")
Router uptime is 18 days and almost 7 hours (so no reboot since module installation).
I know it could be difficult to troubleshoot, just sharing in case of your are curious.
The filter test is case sensitive and only returns exact matches. To Include / Exclude firewall BLOCKED messages, enter BLOCKED and see if that corrects it for you. Additionally, enter BLOCKED AND INCLUDE would be a valid filter string as well
Will try and report.
Ok, I still have a strange behaviour on my setup:
#1: After module installation, login to the router and Filtered using "BLOCKED" (case sensitive as you said) and "Exclude" => OK
#2 and all other attempt: No matter the selection ("BLOCKED" and "Exclude", "BLOCKED" and "Include",...) the log is not filtered. I tried to refresh the page and navigate away and come back, still no filter applied.
Or maybe I don't understand something, sorry if this is the case.
If you can and don't mind,
1. Go to dev tools in your browser, then to the console and see if there are any errors. If there are errors, grab a screenshot of the error and paste it back here.
2. SSH into your router enter the following
 cd /jffs/addons/modsyslogui/ && cat Main_LogStatus_Content.asp > syslog.txt
, then attach that file to your response here
I will be happy to help if it is useful.
  • Dev tools in browser, then to the console: Not sure if this is exactly what you asked, but here is the output.
    • I was on "System Log - General Log" page ("https://routerip: PORT/Main_LogStatus_Content.asp")
  • SSH from router:
    • See file attached
One difference since last week/message: I discovered today that I can do one request (ex: "BLOCKED" and "Exclude") but not a second one (Ex: "Error" and "Include only").
If I want to do a second search/request, I have to move away from the page (ex: click on another tab of go back to "network Map" page) and I can do another request, but again, not another one in a row without leaving the page and going back.
Hope I am clear
I can`t attach the file, I don't know why.
I also tried to insert it using "SPOILER" feature but was not able.
Hope I am clear
Thanks - the screenshots do not show any errors and I'm not able to see the attached file on my end (but that may be due to file restrictions). Regardless, I believe I found that refresh issue and have the fix included in the v1.1.0 BETA that I posted today looking for testers if you are interested
