DST bug / RT-AC3200 / 380.68_4
Waffull
Router: AC3200
Firmware: 380.68_4
I can't get the router to turn off daylight savings time. I have tried a half dozen different time servers.
Any thoughts?
NTP server has nothing to do with DST. Configure it in the two DST fields that are right above it...
Maybe set the start/end time to the same and that will effectively disabled it?
The DST fields are configured. The proper timezone is set.
I've had the router for more than 2 years, always had your firmware on it. Never had this problem before.
The only reason I mentioned trying multiple NTPs was because DST was configured and was still reading daylight time instead of standard time.
Router: AC3200
Firmware: 380.68_4
Any thoughts?
View attachment 10895 View attachment 10896
If you are referring to the statement below the system day/date/time, it's always there I believe. I agree, if it's none daylight savings period, it should not appear. But what's important is, if the time change is correct, which appears you do.
I have AC3200 / 380.68_4 , DST changed as expected , no problem here.
The situation I ran into is that the time is correct on the router, but the time management settings are one hour off, so something got mucked up.
For example, I have some devices that lose their Internet access at 20:00. Last night, they lost it at 19:00 despite the router time being correct. A restart did not help. I had to add an extra hour to the time management setting for the impacted devices.
Agreed. The message is saying that DST is enabled, which is not the same as being currently in effect. The time is correct.
