Dumb Instant Guard question time...
  • Thread starter Thread starter Deleted member 76260
  • Start date Start date
D
Guest
Does Instant Guard work when connected through mobile/cell network or is it somehow just for wifi connections.
All the answers that I can find to this just mention wifi.
Cheers
Instant Guard is VPN connection to your router. You have to use it outside of your network.
What I was trying to say was if I was in work, for example, using my phone and mobile data and turn Instant Guard on it's still connecting to the router thorugh the VPN?
I think you also need to enable access from WAN for it to work so it’s not actually very secure.
You’re better off spinning up an OpenVPN connection
