Export OpenVPN configuration file
WRobertE
I'm running Merlin's 384.4_2 on a RT-AC68U.
Sorry if this is a dumb question but can the same client1.ovpn file generated by the export function be used on multiple client pc's?
Or do I have to do separate exports to generate separate client configurations?
The exported file can be used to configure multiple devices.
Also, within bounds, you can use a text editor to create different client configurations with different options, like whether to route internet traffic over the VPN or not.
