FCC OET Filings--April
jdabbs
Super Moderator
For a device to utilize the radio spectrum in the United States, the FCC requires hardware manufacturers to apply for the relevant license. These publically-accessible applications typically include manuals, specifications, and photos of internal hardware; from this information the capabilities/performance of a particular device can be estimated weeks before the product reaches retail.
For April 1st-30th:
"D Link Corporation"
DWA-130 Rev C2 11n 2.4 GHz USB Adapter. Realtek chipset.
DIR-300 Rev B1 The original DIR-300 was an 11g router, but this revision may be part of the single stream 11n trend. Ralink RT3050F 1T1R "11n" 2.4 GHz chipset; single RPSMA antenna.
"Cisco-Linksys LLC"
WRT310N Rev 2 Linksys filed a confidentiality request for until after this product is being actively marketed.
WRT120N Another confidentiality request, to be lifted June 30th. 2 2 dBi internal antennas; based on the product name, a new entry-level 11n 2.4 GHz router.
WAG160N Rev 2 Combo ADSL modem/router. 11n 2.4 GHz; Atheros chipset.
"Netgear Incorporated"
WGR612 Rev 1 11g router. Atheros AR2317 SoC.
"TRENDware International Inc."
No filings.
"Belkin International, Inc."
F6D4230-4 Rev 2 Another Ralink RT3050F 1T1R router. In the included manual, they tout the "Enhanced" line (which this router is part of) as being compatible with their G+ MIMO line, but as a single stream device it shouldn't be any more compatible than their G line (which does not have G+ MIMO support explicitly mentioned). Marketing at work?
F5D8055 Rev 2 11n 2.4 GHz USB Adapter. Ralink chipset.
