Flash from AdvancedTomato to AIMesh MerlinWRT
pqb2011
I've converted some T-Mobiles to 68U's running Advanced Tomato and I would like to move to AIMesh. I was *hoping* I could simply cross-flash from Tomato; no success. I also tried flashing MerlinWRT at the Mini-CFE web server(?), which simply re-initializes my Tomato install.
I assume, then, I have to re-flash the CFE in order to move to Merlin? (Which I understand I'd have to do anyway for AIMesh.)
Are there any special procedures I should follow, or should I simply redo my original steps?
Thanks!
Asuswrt-Merlin does not currently support AiMesh.
You should be able to go back to stock using the cfe mine web server, took me a few tries.
You can also try the restoration tool.
Try an old version.
I was unable to flash 380 over DDWRT on my AC56U, but an older version worked (I cant remember which as was a long time ago).
