D
Deleted member 115599
Guest
So I'm normally an ASUS/merlin firmware fanboy but for some reason in the UK all the good ASUS routers are never in stock anymore, BE86U, AX86U, AX86U Pro, none anywhere for RRP from major stores.
Meanwhile the Flint 2 is sometimes as low as £109, so my question is if I used the lastest stable 24.10.5 firmware on the Flint 2, did all the basic setting up, WAN (PPPoE, MTU 1492), enable WiFi, enable hardware offloading for 940Mbps down/110Mbps up connection.
Should I expect a similar experience to my ASUS routers in terms of it "Just works" but with the added bonus of OpenWRTs long term support/stability?
