Frequent WIFI dropouts on 384.6
Zonkd
Today I realised we have been getting random WiFi dropouts on 2 different AC86U's that reside in 2 different households since upgrading them both to 384.6. It first became apparent because Apple TV's and PS4's were disconnecting disrupting Netflix and late night online gaming sessions aggravating a lot of people. Now I've been paying attention it seems to be affecting all devices, though most of them reconnect quickly enough that it won't be a problem. The Apple Tv's cope, but PS4's can't handle it and crash online games.
I've definitely tried everything else; doing factory resets and initialising, clean firmware flashing, flushing nvram, simply using all default settings. I see nothing weird in the system logs.
I decided to abandon ship and flash one of the 86's back to the official firmware. Note I used the latest Firmware version 3.0.0.4.384.32797 rather than the version it originally shipped with. The problem still exists.
My next step will be reverting 1 router to the original firmware version it shipped with 3.0.0.4.382_15098 and see if that fixes it.
Has anyone else seen these Wifi problems and what might be causing it? It can't be an isolated problem because it's happening to 2 different models in 2 completely different households.
What crazy world is this!? :eek::confused:
It is, indeed. But no, I don't have any issues as described by you. I do know that some people have reported wifi related issues with 384.6, but I can't recall what kind of issues. You should probably go through the 384.6 thread for more info on that. I do recall that those who were having issues, didn't have them after updating to 384.7 alpha. I've ran alpha 1 and 2 for a while, both were rock solid, so you could give that a try.
I would disable:
1 Mu-Mimo
2 Explicit Beamforming
3 Universal Beamforming
This will further stabilize your 2.4G network..;)
In addition to @skeal's suggestions, see this post by @scjr for more settings to optimize your wifi. Check whether the channels suggested are not too crowded. I did a wifi survey and left both bands at auto at first to see which channel was preferred by the router. I chose channel 52 for the 5Ghz band as channel 44 was already being used by both my neighbors. This setup seems to work very well for me.
I saw this too on my 86u with Merlin's 384.6. I notice my google home devices would drop out for a couple seconds randomly while streaming music. I loaded the wifi QOS patch version 384.32683 and there is no more wifi drops, but its no longer available.
https://www.snbforums.com/threads/s...limited-by-qos-on-rt-ac86u.44952/#post-418433
You can try 384.21140 though as the developer says its the same except for the QOS fix.
-Supe
I'm seeing it here on my AC86U as well. It started with the *.6 alpha, but continued through the release and into the .7 alpha and beta. I mostly am aware of it on the 2.4G band, as I have several smart LEDS, power switches, etc. I've tried all the settings listed here in as many combinations as I could to no avail. Today I punted and did a factory reset as I had not done one in quite a while. I know its not interference as I live in a rural area and there are literally no other networks detectable.
If the reset doesn't work, I'm out of ideas.
I loaded the latest official and it hasn't had the random drops with my google home devices, you can give it a try:
https://www.snbforums.com/threads/asus-rt-ac86u-firmware-release-3-0-0-4-384_32799.48842/
I made the changes and disabled all the things they suggested and also upgraded to ASUS MERLIN RT-AC86U_384.7_beta1 and I have not seen any more wireless dropouts yet. The 5G network is definitely stable now. I need to keep watching the 2G network. Hopefully this is fixed. I will post my settings at a later date.
