Stephen Becker
Has anyone found a way to create a gre (or gre-like) tunnel on an Asus-Merlin router? Using the ip tunnel command fails, it looks like that kernel mod is not included.
My goal is to enable site-to-site routing, so that every device at every location can communicate with each other. I have already installed bird4 via Entware to enable OSPF, I have that working, just can't seem to create routeable interfaces between the routers.
I tried using OpenVPN, and can't seem to get it working (it works as designed, I just can't make it work for my purposes). I disabled NAT on the client side, verified that OSPF created the needed routes, made sure iptables shows bi-directional access. But I can't seem to route across OpenVPN tunnels, there seems to be something there that is enforcing the traditional VPN client-server concept.
NOTE: this forum does not allow you to search gre because it is too short, and searching tunnel returned too many results about basic VPN conversation.
