GT-AX11000 on 388.1 - Wireguard and OpenVPN pro - IPTV Disconnects
wizin
I have RT-AC86U on AI Mesh as well
I have 2 VPNs configured
1 on OpenVPN pro
1 on Wireguard
One of my IPTV which is not on any VPN - loses connection and looks for network, even though it has an IP. I captured the log today when it happened
Same setup never hapenned before 388.1
When this happened last time, I had to switch from googl to ISPs DNS
Jan 9 02:39:12 ovpn-client2[14447]: TLS: tls_process: killed expiring key
Jan 9 02:39:13 ovpn-client2[14447]: TLS: soft reset sec=3600/3600 bytes=54559/-1 pkts=1399/0
Jan 9 02:39:14 ovpn-client2[14447]: VERIFY OK: depth=1, CN=TG-VPN-CA
Jan 9 02:39:14 ovpn-client2[14447]: VERIFY OK: depth=0, CN=server
Jan 9 02:39:14 ovpn-client2[14447]: WARNING: 'link-mtu' is used inconsistently, local='link-mtu 1586', remote='link-mtu 1601'
Jan 9 02:39:14 ovpn-client2[14447]: WARNING: 'comp-lzo' is present in local config but missing in remote config, local='comp-lzo'
Jan 9 02:39:14 ovpn-client2[14447]: Outgoing Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Jan 9 02:39:14 ovpn-client2[14447]: Incoming Data Channel: Cipher 'AES-256-GCM' initialized with 256 bit key
Jan 9 02:39:14 ovpn-client2[14447]: Control Channel: TLSv1.3, cipher TLSv1.3 TLS_AES_256_GCM_SHA384, peer certificate: 2048 bit RSA, signature: RSA-SHA256
Jan 9 02:39:25 kernel: [BLOCKED - INBOUND] IN=eth0 OUT= MAC=40:b0:76:c2:4f:00:68:ab:09:67:6d:8b:08:00 SRC=198.199.96.81 DST=162.156.165.66 LEN=40 TOS=0x00 PREC=0x00 TTL=247 ID=54321 PROTO=TCP SPT=49679 DPT=8980 SEQ=2197845935 ACK=0 WINDOW=65535 RES=0x00 SYN URGP=0 MARK=0x8000000
Jan 9 02:39:27 wlceventd: wlceventd_proc_event(491): eth7: Deauth_ind 88:83:5D:40:8C:03, status: 0, reason: Deauthenticated because sending station is leaving (or has left) IBSS or ESS (3), rssi:0
Jan 9 02:39:28 wlceventd: wlceventd_proc_event(508): eth7: Disassoc 88:83:5D:40:8C:03, status: 0, reason: Disassociated because sending station is leaving (or has left) BSS (8), rssi:0
