Guest isolation on mesh node when in access point mode
Dakusan
I just bought 2 ASUS ZenWiFi AX6600 routers which are running the up-to-date stock firmware 3.0.0.4.386_46061 and are in access point mode. I have been able to get guest isolation (blocking access to the local network) working on the primary access point with
ebtables -t broute -A BROUTING -i wl1.1 -p IPv4 --ip-dst 192.168.1.0/24 -j DROP
I am wanting to also get guest networks working the same way with my mesh nodes. Unfortunately, this seems to be a rather new feature (the Guest Network “Sync to AiMesh Node”), so there isn't much information on it that I can find.
The mesh node is connected to the primary node via the secondary 5ghz channel, so I think the rule has to do something with that routing. I tried adding all of the following to the mesh node, but none of them worked.
ebtables -A FORWARD -i wl1.1 -p IPv4 --ip-dst 192.168.1.0/24 -j DROP
ebtables -A INPUT -i wl1.1 -p IPv4 --ip-dst 192.168.1.0/24 -j DROP
Any thoughts on how I might make this possible?
That is one of the things I like about my eero pro units, even in their Bridge (AP) mode they can separate the Guest network across all nodes. I was never able to do that with any of the Asus wifi routers I had.
