Guest network drops
BWong
I'm having a small problem. I bought this router because I like to game and this is capable of running guest networks. My main network uses WPA-2 security but I need to have a guest network running WEP to allow my Nintendo DS lite to connect. This is where I'm having my problem.
I am able to connect with the Nintendo, but as soon as I find a match and start playing I get dropped. I've tried all of Nintendo's fixes (manual IP, disabling firewall, placing the DS into a DMZ, port forwarding, etc) and I am able to complete around 1 out of 4 of my matches.
Right out of the box everything worked great, I was running the .178 firmware then. I decided to upgrade and then this started happening. I've cleared the NVRAM correctly and even went back to .178 with no success.
I'm sure it's a guest network problem because if I place my main network into WEP mode I'm able to connect and play for hours on end. As soon as I switch it back and enable the guest network I get drops all over the place.
Any ideas?
Do you see any clues in your router log?
It looks like it's just releasing my IP.
Jan 1 23:03:59 dnsmasq-dhcp[505]: DHCPDISCOVER(br0) 00:21:47:72:82:20
Jan 1 23:03:59 dnsmasq-dhcp[505]: DHCPOFFER(br0) 192.168.1.131 00:21:47:72:82:20
Jan 1 23:04:00 dnsmasq-dhcp[505]: DHCPREQUEST(br0) 192.168.1.131 00:21:47:72:82:20
Jan 1 23:04:00 dnsmasq-dhcp[505]: DHCPACK(br0) 192.168.1.131 00:21:47:72:82:20 NintendoDS
Jan 1 23:10:16 dnsmasq-dhcp[505]: DHCPRELEASE(br0) 192.168.1.131 00:21:47:72:82:20
Jan 1 23:10:38 dnsmasq-dhcp[505]: DHCPDISCOVER(br0) 00:21:47:72:82:20
Jan 1 23:10:38 dnsmasq-dhcp[505]: DHCPOFFER(br0) 192.168.1.131 00:21:47:72:82:20
G Where is my Guest Network UI tab? Facebook??? ASUS N Routers & Adapters 4
