Guest network giving two sets of IP
banz
This is my Guest network. I've got Yazfi and running 386.3_2 firmware. Clients on this 2.4G network should only be getting 192.168.2.0/24 IP. However some devices are picking up my internal 192.168.1.0/24 network. Any idea what is going on?
I also tried pinging these 192.168.1.0/24 IP that is on the guest network. Not reachable. Some of my IOT devices are showing that they got the 192.168.1.0 IPs when I checked, but they definitely not pingable but however internet is still working on them.
Something odd going on?
Yes, this happens when you remake GUEST 3 on GUEST 1 and do not reboot the router.
Did you reboot the router after you made the guest network 1?
Guest network 3 will issue dhcp addresses from your local LAN segment. Although it has its own vlan and access between networks is closed, I still recommend the classic vlan scheme where there is a separate dhcp server. This option is possible only in the guest network 1, as well as its distribution to all AiMesh nodes
I do a scheduled reboot weekly and have been running like this for over a year. Everything seems to be running okay. It's just annoying when I go to wireless logs and it shows the wrong IP address.
I'm using aimesh. Also have a lot of settings so I really don't want to do factory reset. I usually just do backup and restore configs when I upgrade the firmware.
