Guest Network Pro + VLAN 52 breaks DHCP when LACP is enabled
i5Js
Hi everyone,
I'm running an ASUS AXE16000 with Merlin firmware and have several VLANs set up at home. One of them is VLAN 52, which I use with Guest Network Pro for a dedicated WiFi network for the kids.
Everything works fine when I connect the router to my switch (a Cisco SG300-28) using a standard single Ethernet cable. The SSID is active, VLAN 52 is correctly configured, DHCP is working, devices get IPs, no issues.
However, the problem starts when I enable LACP on the ASUS (eth1 + eth2) and set up a port-channel on the switch. The bond interface (bond0) is created, and I can see bond0.52 and the br52 bridge still intact, but:
DHCP on VLAN 52 stops working.
Devices can join the WiFi network, but they never get an IP.
I've verified that bond0.52 is part of the correct bridge, the VLAN is tagged properly on the switch, there's no ingress filtering, and everything works again the moment I disable LACP and go back to a single link.
Has anyone seen this behavior before? Could it be something with how dnsmasq or the network stack in Merlin handles VLANs over bonded interfaces?
Any ideas or suggestions are welcome!
Thanks in advance.
I believe what you are referring to as LACP is the setting on the router LAN/VLAN/Profile page? If so did you see the comment "VLAN profile here refers to create a VLAN only network. If you want to create VLAN with DHCP, please go to Guest Network Pro."
Hey.
Thanks for your message,
I’m sorry, but I don’t understand. DHCP is enabled in GNP profile and LAN, for the main network.
DHCP in GNP network was working fine till I activated LACP in the router
