Happy New Year to our Asuswrt-Merlin Addon Community! RTRHTR v1.5 RELEASE CELEBRATION!
Viktor Jaep
Part of the Furniture
Wanted to wish everyone a HAPPY 2026, and hope you all have a great NEW YEAR'S celebration!! We know it's cold and chilly out there! So to ring in this New Year, @Tech9 and I wanted to share the latest results of the RTRHTR project script we've been working so hard on these last few years. Through a lot of trial and error, and many, many routers later, including several total losses of @Tech9's aircraft with integrated RTRHTR avionics, we think we've finally come up with a solution that will work for all routers. That's right... RTRHTR is no longer geared just for the ailing RT-BE92U (which truthfully is about to light itself on fire anyways, RTRHTR not required!). Enjoy the new release!
RTRHTR v1.5 (Released: December 31, 2025)
What's new!?
MAJOR:
AiProtect Core Reactor Meltdown Optimization -- We’ve finally bypassed the hardware thermal throttle not only on the RT-BE92U, but all routers. The CPU no longer requests cooling as we simply deleted its understanding of what cool means. It just wants it hot. In fact, the hotter the better. We are seeing sustained temperatures of 4,000° Kelvin.
MINOR: IoT Integration -- Added support for Philips Hue by hacking @JGrana's Huetil script. Your lights will now automatically turn deep red and pulse in sync with the router's structural integrity failure.
MINOR: Nest Protect Override -- The script now aggressively jams the WiFi signal of nearby smoke detectors, ensuring your cozy fire isn't ruined by blaring alarms or the fire department.
MINOR: New "Avionics" Mode (In honor of @Tech9) -- By over-volting the cooling fans to 50,000 RPM before abruptly seizing the bearings, the router now generates enough momentary thrust to simulate a stall-spin accident. We tip our hats to those aviation enthusiasts out there who were looking forward to this feature.
MINOR: Scent-Based Notifications -- Why check logs? We’ve mapped specific burn smells to system events: (1) Burning Ozone: WAN Connected, (2) Melting ABS Plastic: 5GHz Band Active, (3) The Smell of Burning Cat Hair: Your very, very last MerlinAU Firmware Update Completed Successfully (Huge thanks to @ExtremeFiretop and @Martinski for dedicating the time to integrate this important feature with MerlinAU).
MINOR: Experimental Feature: WiFi 7 "Microwave" Beamforming -- We’ve retuned the 6GHz antennas, even if you don't have them. In fact, we'll turn your 5GHz antennas into 6GHz antennas to make this functionality work. Instead of transmitting data, they now transmit pure concentrated microwave heat radiation. You can now reheat a frozen burrito in record time by simply placing it on top of the unit and trying to stream a 4K youtube video.
FIXED: Addressed a critical bug where the router would occasionally route a packet successfully. We are sorry for this inconvenience. This has been patched. 100% of CPU cycles are now dedicated to providing you that much-needed heat.
FIXED: Resolved an issue where the "Emergency Shutdown" feature actually incorrectly shut down the router. It now simply issues a lockdown command to your smart home locks to keep that cold air out of your home.
Download Link: [LINK REMOVED BY SNBFORUMS.COM AND THE GENEVA CONVENTION]
Alternate Link:
curl --retry 3 "https://raw.githubusercontent.com/ViktorJp/RTRHTR/main/rtrhtr.sh" -o "/jffs/scripts/rtrhtr.sh" && chmod 755 "/jffs/scripts/rtrhtr.sh"
Significant Screenshots:
Sadly, I kept my laptop too close to the router... maybe next time I can capture a screenshot before the keys start sticking together.
Script History
RTRHTR v1.2 -- Released : September 5, 2023
Now featuring the ability to excessively overclock not only the CPU, but the DRAM, NVRAM and attached flashdrive as well in order to create an even more efficient heat source during extreme cold spells. Instructions are now also included on how to attach a small metal grate to the antennas in order to BBQ the meat(s) of your choice directly over your router! The dripping fats actually help ignite further heat within your routers' enclosure to keep you and your family warm during the coldest cold snaps! Enjoy!
RTRHTR v1.0 -- Released: December 23, 2022
Introducing RTRHTR v1.0 -- An Asus-Merlin Script that is designed to push your routers' CPU to the limits using several undocumented overclocking techniques to double or even triple your CPU BTU output, in order to create as much heat as possible so you and your family may stay warm during these awful cold snaps.
Disclaimer: This script will burn your router to the ground, but that's the point, right? ;)
</tongue-in-cheek>
What have you been drinking already tonight, @Viktor Jaep? 🤣
Can confirm that I may or may not have perhaps or not with some uncertainty that I could have had a beverage of unknown contents or not.
Absolutely brilliant, love all the new features, especially the Burrito Warmer. That's a winner.
But now, I think we need RTRHTRMON ...
