Release Asuswrt-Merlin 3004.388.10 is now available
@RMerlin there is a compatibility issue with Guest Networking and nodes that are on 3004 instead of 3006. The GT-AX11000 Pro had 3004 firmware but now is moved to the 3006 which cant seem to handle basic guest networking that the old 3004 branch was capable of handling. With a 3004 and a 3004 node I am able to have mesh network guest network on both my bands -- This doesn't work with Guest Network Pro. Is there a way to give users the choice and build both branches - Or are any fixes coming out for that - I know you don't handle that code specifically but even the new betas don't seem to have new code for wifi 6 routers. It looks like new GPL is just for wifi 7 routers.
Have you tried latest Asus baseline firmware?
You mean stock ? -- All I know is the 3004 firmware that ended being created when the base switched to 3006 worked with guest network functionality when nodes are on and only have available 3004 firmware such as the XT8's. This new Guest Network Pro isn't so pro because it cant even handle what the older firmware was capable of doing =(
Yes, I mean "stock" for the node. I never have had issues with mix of 3006 and 3004 firmware for router an AiMesh node(s).
The XT8 Nodes with a GT-AX11000 Pro router don't populate anything but one band - So for example if I set up a guest network that has an SSID - Test & I selected both bands 2.4 & 5ghz - Only 2.4 will show. If I change that and I select only 5ghz - Only the router will show and no nodes will have a guest network - If I create two guest networks - One for 2.4ghz so Test 2.4 & One for 5ghz - Test 5ghz, Only Test 2.4 will show !
@visortgw there is 3 tab thread about ComputerSteve’s 3004/3006 issue here, but it seems to have petered out.
[EDIT] And this related thread:
Right -- The consensus seems to be it doesn't work right. At least with mixing the firmware versions - This really doesn't help people who have mixed firmware systems.
I’m not sure that was the consensus, but I would agree the implementation of Main/Nodes with 3006/3004 is different (limited?) vs 3004/3004 (which is also limited) as opposed to how it should work, and does, with 3006/3006.
I’m not sure this is something @RMerlin can fix for you though, I believe it’s all down to Asus i.e. I’m almost certain @RMerlin cannot fix it in this or any other firmware, unfortunately.
So the options are I guess reverting to HW that can do 3004/3004, living with 3006/3004 implementation, upgrading to the all singing all dancing 3006/3006 (or 3006/3006VLAN) option or… bailing out and moving to a different manufacturer.
Yeah, another issue appears to be when you try to have two 3004 triband nodes to connect over the previously dedicated wireless backhaul. I've confirmed that both 5 ghz-1 and 5 ghz-2 remain active, but it will not function as a dedicated wireless backhaul anymore. Each node will try to connect to the main router instead... If I try the same with BT8's, the wireless backhaul works as expected.
Upgraded my RT-AX86U from 3004.388.9_2 to 3004.388.10_2, performing a full factory reset (clean install).
I kept the same SSID and WiFi password as before. Despite that, all devices needed to be reset — HomeKit devices required hard resets, and iOS/macOS devices needed to forget and re-add the network. This update took about 4 hours, compared with my usual 2.5 hours for a full reset. Everything is working now.
Update (first 24 hours):
  • iPhone: Disconnected unexpectedly from the 5 GHz network overnight. Continuing to monitor.
  • Web GUI: Once, while viewing DNS Director settings, the interface suddenly logged me out and redirected to the main login page. I haven’t been able to reproduce this.
  • Used the same SSID and password as the previous firmware version. The installation required power-off reboots/resets and reconfiguring WiFi settings on all devices, except those on the guest network. I don’t recall this difference during previous firmware updates, including six clean installs.
Can anyone assist me in possibly figuring out why my RT-88AXU will not take the 3004.388.10 update? I've been running this code for a while now, so I've completed a number of version upgrades with no issue. .10 just doesn't go! No error messages, no warnings, nothing. Everything acts like the upgrade is proceeding normally but when the router reboots, it is still at .9. I've obviously verified the SHA of the download(s), followed all troubleshooting (clearing memory space, rebooting then trying upgrade), everything. I'm at a loss. Any help with this would be greatly appreciated.
Have you tried installing MerlinAU via amtm (option 8) to assist with the update?
You can try update using ASUS Firmware Restoration version 2.1.0.3.
Get it from here:
You can see it after clicking on "See all downloads"
I have no idea what that is. I will need to research this. I will take a look to see if I can get any information.
MerlinAU is an auto update script for Merlin firmware developed by @ExtremeFiretop and @Martinski. You can find details here and here. My experience is that it resolves most firmware update issues.
MerlinAU is a great way to rule things out... If MerlinAU doesn’t work, it’s likely not a simple user error, like forgetting to remove any attached USBs or grabbing the wrong firmware.
It's also great for anyone looking for minimal maintenance, and it helps remove a lot of the learning curve new users might face.
Another nice benefit is that if the script doesn’t work for whatever reason, you can skip most of the basic troubleshooting and jump straight to steps like doing a factory reset or, in the worst case, using tools like the ASUS Restore utility mentioned by another user above.
The firmware loaded ok on my AX88U ok. No problems. That's weird problem. The only time I have seen this problem; I just reboot the router and then try to upgrade the firmware.
I agree with the last comment. No problem on my AX88U either.
Everything has been working perfectly for several weeks now with the latest firmware version.
I also restart the router before each update and have never had any upgrade issues.
Just in case, check if you haven't downloaded the RT-AX88U_PRO wrong FW...
double check you downloaded the correct f/w i had this issue when i ffed up and had the wrong device ie bt86u vs bt88u firmware and was trying to load it.
