Hi all,
I'm planning to build a NAS for 5 or 6 HDD's. OS will be Ubuntu server. Squeezeserver will be installed. A fast running Squeezeserver is of more priority than NAS throughput. I have no graphical needs. Case-wise I think to use the Antec NSK6580. Most likely it will be running 24/7, so power consumption is important.
There are numerous suggestions on the web (also in this forum on the fast Ubuntu NAS), but those mb's or cpu's are being discontinued. So, I'm looking for a combination of a 6-SATA low power motherboard (Ubuntu compatible, Gigabit lan) with a low power consuming (duo core) CPU that's still fast enough for Squeezeserver.
The two set I was thinking of is (and are readily available):
1. Intel DP43TF with Intel E5200 or
2. Asrock A780GMH/128M with AMD Athlon II X2 215 / 2.7 GHz processor
I guess power consumption for those is not optimal. Any comments on this or any better suitable alternatives?
Any help is much appreciated, Ralph
