Hi all!
I have a problem with my web cam. I am using N66U with Merlin FW 380.57. My web cam is connected to the guest network which is setup with Access Intranet = Disable. I also have port forwarding from a non standard port to the web cam's access port. The web cam is setup to get an IP via DHCP, but on the router side I have it in the manually assigned IP list.
My problem is that I have no access to the web cam unless I enable the "Access Intranet" on the guest network. Is that normal?
I tried accessing it both via the internal IP and the external one. If I enable the intranet access on the guest network I can connect to the camera.
It was working OK before, when I was using Tp-link Archer C7 as the main router and the Asus N66U as an AP. The Tp-link has similar setting called "Allow Guest To Access My Local Network" and it was Off.
My idea behind this setup was that if somebody hacks the camera, he should not have access to my other devices from it.
