First of all I'd like to thank you again @RMerlin for the truly awesome work you put in this FW. You can expect a beer or two coming your way. Thanks!
I have to say I'm really happy about the latest FW that brought a lot of improvements to RT-AC3200 for me and a lot of others I imagine. I'm really happy to see TLS support for the FTP server, and also the low nvram fix for AC3200.
Now to the point.
I'm probably doing this wrong, but TLS seems to have brought out some issues for me. I'm used to connecting to my FTP server using my android device and FX File explorer (reconfigured to use encryption) but that doesn't seem to be possible anymore. I get the error:
I'm also sharing some files over FTP with my brother who's running Kodi 17.1 and he can't connect to the server anymore. Connecting to the server using FileZilla works fine.
Is there anything I can do to make this work?
Any help would be highly appreciated. Thanks!
Now to the point.
The host "192.168.1.1" is configured to require SSL certificate reuse for encrypted connections. This feature is unfortunately not supported by the underlying Apache FTP library at the present time.
