Homeassistant SSH stops working with 384.18
truglodite
Lots of folks including myself are using the ssl deamon ssh server on our routers to track wifi connections of our phones (this is used for home automations). Nothing new there, and Homeassistant has a nice asuswrt component that in the past has worked reliably. However, with the latest merlin firmware, there have been verified reports that the ssh connection no longer works. It's a problem with HA, since ssl works fine for everyone from other devices.
Here are some related links on this subject:
https://community.home-assistant.io/t/asuswrt-ssh-login-failing/208525/4
https://github.com/home-assistant/core/issues/37269
Does anyone have any clues as to what may have changed, or what could be looked at by the HA devs to fix this? My best wild guess is dropbear or openssl got an update that deprecated the cryptos being used by HA, but not sure. This issue is fresh and folks are just looking into it. Any help you guys can offer would be greatly appreciated.
Thanks,
Kevin
I suppose I shouldn't have called dropbear an deamon. :)
If you are referring to the SSH server, make sure your client supports modern ciphers. Obsolete algos like 3des and cbc were dropped a few months ago.
You mean SSH don't you, not SSL?
Yes ssh, oh boy I botch that post pretty bad! I went back and changed the title to avoid confusion.
Thanks for the tip Eric, I am suspicious that is what is going on here. I already mentioned that in the issue report. Hope they get that sorted so I can go back to .18 on my router.
Which SSH cifhers are supported by SSH server, after 384.18? Thanks
GCM (like AES-256-GCM), Chacha20 are supported. I don't know the complete list.
