How do I confirm that DNSCrypt is working?
spartan77777
I am running shibby's "Tomato Firmware 1.28.0000 MIPSR2-110 K26 USB Mega-VPN" on a RTN16.
Checked the "Use dnscrypt-proxy" box to enable DNSCrypt and changed both of my DNS servers to 127.0.0.1.
When I run a test at dnsleaktest.com I get "we detected 0 DNS server listed below".
This is the result I get regardless of the OpenVPN client turned off or on.
Is this sufficient proof that it is working or is there any other test I should run?
I have to following log activity:
Jul 19 02:48:47 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPINFORM(br0) 192.168.2.188 4c:eb:42:64:51:ea
Jul 19 02:48:47 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPACK(br0) 192.168.2.188 4c:eb:42:64:51:ea GKDM4
Jul 19 02:51:01 TOMATO cron.info crond[566]: crond: USER root pid 1174 cmd ntpsync --cron
Jul 19 02:51:01 TOMATO user.info ntpc[1175]: Time: Fri, 19 Jul 2013 02:51:01 -0400, no change was needed.
Jul 19 02:58:50 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPINFORM(br0) 192.168.2.188 4c:eb:42:64:51:ea
Jul 19 02:58:50 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPACK(br0) 192.168.2.188 4c:eb:42:64:51:ea GKDM4
Jul 19 03:00:01 TOMATO cron.info crond[566]: crond: USER root pid 1185 cmd logger -p syslog.info -- -- MARK --
Jul 19 03:00:01 TOMATO syslog.info root: -- MARK --
Jul 19 03:08:52 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPINFORM(br0) 192.168.2.188 4c:eb:42:64:51:ea
Jul 19 03:08:52 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPACK(br0) 192.168.2.188 4c:eb:42:64:51:ea GKDM4
Jul 19 03:12:18 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPINFORM(br0) 192.168.2.188 4c:eb:42:64:51:ea
Jul 19 03:12:18 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPACK(br0) 192.168.2.188 4c:eb:42:64:51:ea GKDM4
Jul 19 03:15:03 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPINFORM(br0) 192.168.2.188 4c:eb:42:64:51:ea
Jul 19 03:15:03 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPACK(br0) 192.168.2.188 4c:eb:42:64:51:ea GKDM4
Jul 19 03:16:40 TOMATO daemon.notice openvpn[948]: TLS: soft reset sec=0 bytes=705713132/0 pkts=756863/0
Jul 19 03:16:40 TOMATO daemon.notice openvpn[948]: VERIFY OK: depth=1, C=UK, ST=NR, L=Attleborough, O=Hide My butt! Pro, OU=VPN, CN=vpn.hidemyass.com, emailAddress=ca@hidemyass.com
Jul 19 03:16:40 TOMATO daemon.notice openvpn[948]: VERIFY OK: nsCertType=SERVER
Jul 19 03:16:40 TOMATO daemon.notice openvpn[948]: VERIFY OK: depth=0, C=UK, ST=NR, L=Attleborough, O=Hide My butt! Pro, OU=VPN, CN=server, emailAddress=vpn@hidemyass.com
Jul 19 03:16:41 TOMATO daemon.notice openvpn[948]: Data Channel Encrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jul 19 03:16:41 TOMATO daemon.notice openvpn[948]: Data Channel Encrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jul 19 03:16:41 TOMATO daemon.notice openvpn[948]: Data Channel Decrypt: Cipher 'BF-CBC' initialized with 128 bit key
Jul 19 03:16:41 TOMATO daemon.notice openvpn[948]: Data Channel Decrypt: Using 160 bit message hash 'SHA1' for HMAC authentication
Jul 19 03:16:41 TOMATO daemon.notice openvpn[948]: Control Channel: TLSv1, cipher TLSv1/SSLv3 DHE-RSA-AES256-SHA, 1024 bit RSA
Jul 19 02:17:19 TOMATO daemon.info dnscrypt-proxy[560]: Refetching server certificates
Jul 19 02:17:19 TOMATO daemon.info dnscrypt-proxy[560]: Server certificate #1369080797 received
Jul 19 02:17:19 TOMATO daemon.info dnscrypt-proxy[560]: This certificate looks valid
Jul 19 02:17:19 TOMATO daemon.info dnscrypt-proxy[560]: Server key fingerprint is 915C:9A0C:5F0F:5EB4:784E:E450:FE8B:C115:B1DE:5538:7718:25D5:C305:CCB7:9532:0309
Jul 19 03:18:55 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPINFORM(br0) 192.168.2.188 4c:eb:42:64:51:ea
Jul 19 03:18:55 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPACK(br0) 192.168.2.188 4c:eb:42:64:51:ea GKDM4
Jul 19 03:25:03 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPINFORM(br0) 192.168.2.188 4c:eb:42:64:51:ea
Jul 19 03:25:03 TOMATO daemon.info dnsmasq-dhcp[531]: DHCPACK(br0) 192.168.2.188 4c:eb:42:64:51:ea GKDM4
