Entware How do i remove transmission?
Furio
Hellow,
I am noob under linux and entware, i want to remove transmission installed on a router with wrtmerlin.
I had problems with an update and i want to remove to start again with a new instalation (reinstall don´t work)
I tried using the command "opkg remove transmission" in the directory "/tmp/home/root#" but it doesn´t work.
The answer is "No package remove"
Thanks for your help.
Hellow,
I am noob under linux and entware, i want to remove transmision installed on a router with wrtmerlin.
Not really sure. But from this list https://pkg.entware.net/binaries/armv7/Packages.html, you may want to try the "opkg remove transmission-package-name" for each of the packages listed below
