How to compile 384?
Shonk
Im having problems getting 384 to compile on my ubuntu64 box
any chance of someone helping me get this compiling for my rt-ac88u
atm im opening terminal
su (to get root i know i could remove sudo but it makes no diff)
cd /home/shonk
git clone https://github.com/RMerl/asuswrt-merlin.ng
git clone https://github.com/RMerl/am-toolchains
sudo mkdir -p /opt
sudo rm -rf /opt/toolchains
sudo ln -s /home/shonk/am-toolchains/brcm-arm-hnd /opt/toolchains
sudo rm -f /opt/brcm-arm
sudo ln -s /home/shonk/am-toolchains/brcm-arm-sdk/hndtools-arm-linux-2.6.36-uclibc-4.5.3 /opt/brcm-arm
its just a case of setting the paths now
but the ones i have tried dont seem to work
asuswrt-merlin.ng is in /home/shonk/
am-toolchains is in /home/shonk
then its
cd /home/shonk/asuswrt-merlin.ng/release/src-rt-7.14.114.x/src
make clean
time make rt-ac88u
sudo ln -sf /home/shonk/am-toolchains/brcm-arm-sdk/hndtools-arm-linux-2.6.36-uclibc-4.5.3 /home/shonk/asuswrt-merlin.ng/release/src-rt-7.14.114.x/src/toolchains
Rmerlin has instructions:
https://github.com/RMerl/asuswrt-merlin/wiki/Compile-Firmware-from-source-using-Ubuntu
I don't see that you exported the PATH environment variable unless you added the information to your ~/.profile file. I don't have my desktop with all my build information setup at the moment otherwise I would be able to provide you with a script.
Also I don't think the info kfp is valid. RMerlin moved the toolchains to a completely separate location from the main source code as a result of Github's 1gb source code limitation per repository.
its the PATH environment variable that im after
Here's the PATH I use to build an RT-AC88U firmware. It yelled at me when I did it wrong.
export PATH=$PATH:/opt/brcm-arm/bin:/opt/brcm-arm/arm-brcm-linux-uclibcgnueabi/bin
Can you paste the complete thing for 384
Example of mine for 380
cd /home/shonk/
git clone https://github.com/RMerl/asuswrt-merlin.git
sudo rm /opt/brcm
sudo rm /opt/brcm-arm
sudo ln -s /home/shonk/asuswrt-merlin/tools/brcm /opt/brcm
sudo ln -s /home/shonk/asuswrt-merlin/release/src-rt-6.x.4708/toolchains/hndtools-arm-linux-2.6.36-uclibc-4.5.3 /opt/brcm-arm
export PATH=$PATH:/opt/brcm/hndtools-mipsel-linux/bin:/opt/brcm/hndtools-mipsel-uclibc/bin:/opt/brcm-arm/bin
cd /home/shonk/asuswrt-merlin/release/src-rt-7.14.114.x/src
time make clean
time make rt-ac88u
What compiler errors are you seeing right now? Posting that would narrow the problem down.
Can you paste the complete thing for 384?
Your issue could be 'make clean'. I don't ever trust this command because she is flakey.
### setup Broadcom ARM toolchain for Asuswrt-Merlin
[ ! -d /opt ] && sudo mkdir -p /opt
if [ ! -d ~/am-toolchains ]; then
  cd
  git clone https://github.com/RMerl/am-toolchains.git
fi
sudo ln -s ~/am-toolchains/brcm-arm-sdk/hndtools-arm-linux-2.6.36-uclibc-4.5.3 /opt/brcm-arm
sudo rm -f /bin/sh ; sudo ln -s bash /bin/sh
export LD_LIBRARY_PATH=
export TOOLCHAIN_BASE=
Now just compile it from a clean source.
rm -rf ~/asuswrt-merlin.ng/release/src-rt-6.x.4708/toolchains
ln -s ~/am-toolchains/brcm-arm-sdk ~/asuswrt-merlin.ng/release/src-rt-6.x.4708/toolchains
cd ~/asuswrt-merlin.ng/release/src-rt-7.14.114.x/src
make rt-ac88u
N How to compile from source asus merlin. Asuswrt-Merlin 7
