how to create a ssh tunelling on the router ?
Might have to install openssh over the default dropbear...
One thing to consider - from your desk - Snowflake has been fairly successful at getting past the latest restrictions over in Russia and Iran...
Install that on your desktop PC - and then share internet from it to the other devices...
hey man, snowflake works one time out of 10 and when it works it can't be a solution for someone like me who works on computers all day.
openssh over dropbear, i will have a look, any tutorial or ressources ?
best regards.
best regards.
I think openssh-client and openssh-server are over in entware...
You'll have to disable the dropbear, or move it to a different port
Here's the post where I described how to install the OpenSSH Server on the ASUS router via Entware:
Note that SSH Tunneling is enabled by default for *both* "local" & "remote" port forwarding:
AllowTcpForwarding yes
If you want to be more explicit and based on your needs, you can set it for one or the other:
AllowTcpForwarding local
OR
AllowTcpForwarding remote
HTH.
