I'm looking for some help troubleshooting any issue I'm having with the WAN interface on my RT68U. Is there a telnet command to pull WAN interface stats? Possible CRC errors or anything like that.
I have a Comcast Gig and I have notice that after either rebooting my Router or Cable Modem or disconnecting the cable between them for a couple of seconds and putting it back I get full gig speed (900ish) I'm expecting at any time of the day or night. However after several hours those speed slow to 500 - 600ish Mb. So I'm trying to determine the root cause.
All the setting on the router should be correct:
1. Reset to default and reconfigured the router
2. Disabled QOS
3. Disabled Span Tree
4. Enabled CTF/FA
I have tried different cable modems: MB8600 and CM1000 hoping that it might be an issue with the Gig interface on that side. At this point hoping I can find some clues thru the router stats before I look at replacing the router altogether.
2. Disabled QOS
4. Enabled CTF/FA
