How to totally disable disk error checks?
gjf
Previously I have reported about some problems with disk error checks when big (1 Tb) storage is mounted.
In disk check schedule I have disabled this check, but anyway "ntfsck.000000" folder appears with every reboot of router. I've tried to fix all errors with PC, but anyway the problem appears immediately when I connect storage to router. Looks like it is driver problem.
Is there any way to stop this stupid check or fix memory lack problem?
I believe error checking is drive firmware or drive i/o handling software issue.
Did you reformat the drive and tried? Also see if your drive has f/w update.
This portable HDD works like a charm. And yes - I have reformatted it just in case. And no - there is no any updates for fw (actually manufacturer does not provide updates).
The issue is known and caused by lack ща RAM when big HDD are processed. And that is one of the reason why fork 374.43 exists.
So my question is still valid: how to disable this crap?
/etc/fstab is empty file with zero size according to SSH connection.
Which fstab file do you need?
