Main home network wireless router is D-Link DIR-655.
Also have older spare DIR-625 wireless router (it doesn't accept DD-WRT).
Overall goal: enable an xbox live connection for the kids, by using the older DIR-625 as the internet adapter for the xbox. Make a wireless connection between the main router (DIR-655) and the secondary router (DIR-625).
I guess that in the main router (DIR-655) I'd just assign an IP address to the secondary router, same as if it were another computer on the lan? Is that right?
What settings should I put into the secondary router being used as the internet adapter at the xbox (DIR-625)?
Thank you.
Thank you.
