httpd issue on AC87U (firmware version 384.7_2)
Ionut
I noticed that, whenever I do some changes in the Advanced Settings -> LAN -> DHCP Server -> Manually Assigned IP around the DHCP list, the web interface gets stuck. Everything else continues to work fine, I can connect to it via ssh, no problem.
Any idea if this bug has been already fixed in the beta version ? I noticed that there is something slightly similar fixed in 384.9 (- FIXED: httpd crashes on RT-AC86U (themiron)) but mine is a AC87U, not AC86U so I'm not sure if it's the same issue or not.
Regards,
Ionut
There are no known issue around editing DHCP reservations. Check on the Sysinfo page to ensure you're not running out of nvram.
Nope, I just checked.
It says: 52514 / 65536 bytes
I will do another test this evening, when I get home.
