RMerlin
Asuswrt-Merlin dev
Howdy folks,
There is a newer revision of the RT-N66U that uses a different flash type. This model is *NOT* compatible with Asuswrt-Merlin, nor with any older version of Asuswrt. This is the reason why Asus has pulled all the older firmware versions from their website.
I have the required code that implements support for this new revision. I'm not sure how or when I will find some time to integrate it (work is seriously kicking my butt this week!), but I'll see what I can do.
In the meantime:
If you purchased a NEW RT-N66U, do NOT flash Asuswrt-Merlin until I release 3.0.0.4.372.30_3 (UPDATE: now available).
If you accidentally did flash a non-compatible version, you should in theory be able to boot into recovery mode, and reflash it. The FW versions currently on the Asus website are compatible.
In the meantime:
