In the 5 GHz only 4 channels 374.43
HorstG
Hello, I noticed that I have only 4 channels on my RT-N66U in 5GHZ.
Can I change this somehow?
My channels ar 36-40-44-48....
FW is 374.43. Update Needed ??
Thank you
Sorry for my Bad Englisch.
Horst
Thank you
Horst
If you only see lower channels, then your firmware doesn't support DFS/TPC and thus is not allowed to use upper channels. You can check for an updated firmware, or use an alternative firmware like dd-wrt that supports DFS/TPC
hello
So the 5 Ghz channels with the firmware be determined
me or the hardware?
What can i do??
Have all RT-N66U this?????
EDIT: Have the AVM FritzBox 7490 all channles???
channels
hello
me or the hardware?
What can i do??
All Asus routers have this issue. for others like Linksys it is the same. I have an AVM 7340 and that offers all the allowed channels. I bet that the 7490 does too.
You forgot "with stock settings".
Here's N66U for you with 12 channels on 5GHz:
hello
this means that DFS is not supported by ASUS?
Will there be an introduction of DFS / TPS in Merlin for Rt-N66U yet?
There remains only one other router For example, AVM buy because there all 5 GHz channels are allowed.
Anyone knows whether support DD-WRT / OpenWRT or similar DFS?
Cu Happy Week End..
