Intel 7260 M.FL plug?
Winejug87
Hello all.
New to the forum, but I registered to ask this question after searching here.
I am trying to upgrade the wireless card inside my ux31a. I've taken off the bottom cover and confirmed that the card I have (Intel 6325) uses M.FL antenna connectors.
However, the card I want (Intel 7260) uses U.FL connectors apparently.
I've attempted to search for an answer to this, but so far the Internet world has come up short so I thought I'd ask here.
Does anyone have an idea of how I could use the 7260 in my ultrabook, or if intel is planning on releasing a version of the 7260 that uses M.FL connections?
Any help would be appreciated.
Thanks in advance!
Are you positive it is m.fl? I am only aware of the 6235 being made with u.fl connectors.
Just to note for others having the same issue (I'm one of them), this is confirmed:
https://wikidevi.com/wiki/Intel_Centrino_Advanced-N_6235_(MHF4)
My searching reveals no easy (i.e. without precision soldering) way around this issue. Intel made the 6235 with a mhf version, but not the 7260.
Bright side: In the long run, it's probably better that there's (basically) one connector standard going forward...
I know it sounds dumb I m sorry . But what is the difference between u.fl and m.fl ? And what do they stand for ?
Found u.fl but I'm puzzled why they would put beer keg connectors or m.fl's on wireless cards :D all kidding aside I figure the m.fl is the post and slide on 90 degree like my IBM t43 and t60 thinkpads use.
I know this is a really old thread, but there doesn't seem to be any antenna (RF connector) product or specification called "M.FL"
Based on the naming convention and comparison to U.FL, I assume this M.FL would be a Hirose product, but it does not exist:
https://www.hirose.com/product/en/products/RF_Coaxial/Micro+Coaxial+Connector/
The OP's original card is probably the "Low Profile" version of the "Intel Centrino Advanced-N 6235", which is model 6235ANHMWLPG.
http://www.intel.com/content/www/us/en/processors/centrino/centrino-advanced-n-wimax-6235-brief.html
It has MHF4 antenna connectors, which are now commonly found in NGFF/M.2 wifi adapters.
The regular version of the 6235 has the U.FL connector found on most older Mini PCI Express Half-Height adapters.
Neither U.FL or MHF4 (made under Dai-ichi Seiko's I-PEX brand) are standardized names. They are just de-facto standards based on popular products.
And "MHF" (without the 4) is actually equivalent U.FL in size. Very confusing.
