Intermittent WiFi Disconnects on various Clients; Deauth for "unspecified reason", disassociated, 386.5_2
jksmurf
Over the last month or so I upgraded my RT-AX86U 386.5 as a full reset then dirty upgrade to 386.5_2. Set up is in my sig, Router and 2 AIMESH Clients, I use Smart-Connect, nothing fancy except Diversion w/o the WebUI and an OpenVPN Server, 30-40 DHCP reservations. Clients are also on latest Merlin.
I have been getting, since 386.5 but maybe also before, quite a few Wifi random disconnects on my Wifi Clients, where it doesn't even auto-reconnect, you have to select connect again e.g. in the logs below, on SabiLenovo (a Notebook) which is pretty annoying. I don't even know if the message below are useful or routine, I can say that they are from the exact time of the osberved issues this morning though.
Is there some way I can troubleshoot this please? I know a lot of folks disable Smart Connect, can it really be that bad though, I thought by now it must be reasonably robust?
Anyone else seeing these / similar issues?
Apr  1 05:52:34 hostapd: eth7: STA 40:xx:xx:xx:xx:xx RADIUS: starting accounting session 3DA34DDCF2333CE9
Apr  1 05:52:34 hostapd: eth7: STA 40:xx:xx:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Apr  1 06:01:48 wlceventd: wlceventd_proc_event(505): eth7: Auth 94:xx:xx:xx:xx:xx, status: Successful (0)
Apr  1 06:01:48 kernel: br0: received packet on eth7.0 with own address as source address
Apr  1 06:01:48 wlceventd: wlceventd_proc_event(515): eth7: ReAssoc 94:xx:xx:xx:xx:xx, status: Successful (0)
Apr  1 06:01:48 wlceventd: wlceventd_proc_event(469): eth7: Deauth_ind 94:xx:xx:xx:xx:xx, status: 0, reason: Unspecified reason (1)
Apr  1 06:01:48 hostapd: eth7: STA 94:xx:xx:xx:xx:xx IEEE 802.11: associated
Apr  1 06:01:48 hostapd: eth7: STA 94:xx:xx:xx:xx:xx IEEE 802.11: disassociated
Apr  1 06:01:48 dnsmasq-dhcp[23703]: DHCPREQUEST(br0) 192.168.1.10 xx:xx:xx:xx:xx
Apr  1 06:01:48 dnsmasq-dhcp[23703]: DHCPACK(br0) 192.168.1.10 xx:xx:xx:xx:xx SmurfPC
Apr  1 06:01:50 hostapd: eth7: STA 94:xx:xx:xx:xx:xx RADIUS: starting accounting session 0C1CEDD8820D1773
Apr  1 06:01:50 hostapd: eth7: STA 94:xx:xx:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Apr  1 06:01:50 dnsmasq-dhcp[23703]: DHCPREQUEST(br0) 192.168.1.206 94:xx:xx:xx:xx:xx
Apr  1 06:01:50 dnsmasq-dhcp[23703]: DHCPACK(br0) 192.168.1.206 94:xx:xx:xx:xx:xx SabiLenovo
Apr  1 06:01:51 dnsmasq-dhcp[23703]: DHCPREQUEST(br0) 192.168.1.206 94:xx:xx:xx:xx:xx
Apr  1 06:01:51 dnsmasq-dhcp[23703]: DHCPACK(br0) 192.168.1.206 94:xx:xx:xx:xx:xx SabiLenovo
Apr  1 06:02:03 wlceventd: wlceventd_proc_event(469): eth7: Deauth_ind 94:xx:xx:xx:xx:xx, status: 0, reason: Unspecified reason (1)
Apr  1 06:02:03 hostapd: eth7: STA 94:xx:xx:xx:xx:xx IEEE 802.11: disassociated
Apr  1 06:02:08 wlceventd: wlceventd_proc_event(505): eth7: Auth 94:xx:xx:xx:xx:xx, status: Successful (0)
Apr  1 06:02:08 wlceventd: wlceventd_proc_event(534): eth7: Assoc 94:xx:xx:xx:xx:xx, status: Successful (0)
Apr  1 06:02:08 hostapd: eth7: STA 94:xx:xx:xx:xx:xx IEEE 802.11: associated
Apr  1 06:02:08 hostapd: eth7: STA 94:xx:xx:xx:xx:xx RADIUS: starting accounting session 99682D8877A695A5
Apr  1 06:02:08 hostapd: eth7: STA 94:xx:xx:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Apr  1 06:02:08 dnsmasq-dhcp[23703]: DHCPREQUEST(br0) 192.168.1.206 94:xx:xx:xx:xx:xx
Apr  1 06:02:08 dnsmasq-dhcp[23703]: DHCPACK(br0) 192.168.1.206 94:xx:xx:xx:xx:xx SabiLenovo
Apr  1 06:03:12 wlceventd: wlceventd_proc_event(469): eth7: Deauth_ind 94:xx:xx:xx:xx:xx, status: 0, reason: Unspecified reason (1)
Apr  1 06:03:12 hostapd: eth7: STA 94:xx:xx:xx:xx:xx IEEE 802.11: disassociated
Apr  1 06:03:53 acsd: acs_candidate_score_intf(1133): eth7: intf check failed for chanspec: 0xe832 (36/160)
Apr  1 06:03:53 acsd: acs_candidate_score_bgnoise(1602): eth7: bgnoise check failed for chanspec: 0xe832 (36/160)
Apr  1 06:03:53 acsd: acs_candidate_score_txop(1860): eth7: txop check failed for chanspec: 0xe832 (36/160)
Apr  1 06:03:53 acsd: acs_candidate_score_intf(1133): eth7: intf check failed for chanspec: 0xe932 (40/160)
Apr  1 06:03:53 acsd: acs_candidate_score_bgnoise(1602): eth7: bgnoise check failed for chanspec: 0xe932 (40/160)
Apr  1 06:03:53 acsd: acs_candidate_score_txop(1860): eth7: txop check failed for chanspec: 0xe932 (40/160)
Apr  1 06:03:53 acsd: acs_candidate_score_intf(1133): eth7: intf check failed for chanspec: 0xea32 (44/160)
Apr  1 06:03:53 acsd: acs_candidate_score_bgnoise(1602): eth7: bgnoise check failed for chanspec: 0xea32 (44/160)
Apr  1 06:03:53 acsd: acs_candidate_score_txop(1860): eth7: txop check failed for chanspec: 0xea32 (44/160)
Apr  1 06:03:53 acsd: acs_candidate_score_intf(1133): eth7: intf check failed for chanspec: 0xeb32 (48/160)
Apr  1 06:03:53 acsd: acs_candidate_score_bgnoise(1602): eth7: bgnoise check failed for chanspec: 0xeb32 (48/160)
Apr  1 06:03:53 acsd: acs_candidate_score_txop(1860): eth7: txop check failed for chanspec: 0xeb32 (48/160)
Apr  1 06:04:12 wlceventd: wlceventd_proc_event(505): eth7: Auth 94:xx:xx:xx:xx:xx, status: Successful (0)
Apr  1 06:04:12 wlceventd: wlceventd_proc_event(534): eth7: Assoc 94:xx:xx:xx:xx:xx, status: Successful (0)
Apr  1 06:04:12 hostapd: eth7: STA 94:xx:xx:xx:xx:xx IEEE 802.11: associated
Apr  1 06:04:12 hostapd: eth7: STA 94:xx:xx:xx:xx:xx RADIUS: starting accounting session 2E74E2DBF395B284
Apr  1 06:04:12 hostapd: eth7: STA 94:xx:xx:xx:xx:xx WPA: pairwise key handshake completed (RSN)
Apr  1 06:04:12 dnsmasq-dhcp[23703]: DHCPREQUEST(br0) 192.168.1.206 94:xx:xx:xx:xx:xx
Apr  1 06:04:12 dnsmasq-dhcp[23703]: DHCPACK(br0) 192.168.1.206 94:xx:xx:xx:xx:xx SabiLenovo
ta
k.
If your router is working well ignore the log.
Thank you. The Router is working; but the Clients disconnect. If I just put the log to one side for now and look at the symptoms explained above, there seems to be an issue. Like I suggested above, I have no idea whether the log is telling me the issue lies with the Router, the Client or the Settings on either.
ta
k.
