Hi everyone, I need help to solve this problem.
My home configuration is:
Fritzbox 7490 modem router connected to internet with optical fiber (FTTC), ip 192.168.178.1.
Router Asus RT-AC86U Merlin 384.8_2 connected to the Fritzbox to Wan port, ip 192.168.178.25.
In the Asus subnet I connected the hardware, Tv, Pc, Sat etc. with ip 192.168.1.XX.
On two IP addresses I use OpenVPN and on others I do not.
Being two different networks, is there a way to make them visible by both routers as if they were a Lan-Lan network?
I'll explain…
For example, I connect Wi-Fi to the Fritzbox's wireless network with my Iphone, I can see my hardware connected to the Asus subnet 192.168.1.1?
I tried to do Port Forwarding but without result.
I also tried in the Fritbox to fully open (DMZ) to the ip 192.168.178.25!
Is there any of you who could post me an example of configuration?
Thank you
I'll explain…
Thank you
