iOS real time traffic
Sdr-99xrs
Hello
I have Ryan-ax86u pro and stumbled upon the real time traffic display on the iOS app I’m wondering what is normal in terms of download speeds and upload speeds while it. Meaning if not doing any manual uploads for example, what is a steady upload speed. Or is it all dependent on security cameras etc that use the cloud? I was looking at a list of devices in the device list, which seems to always be incorrect, and I coudltn figure out why my upload is between 1Mbp/s to 4mbp/s other than Google nest cameras. To me, it seems it shouldn’t be that high if I am not uploading anything to a server for example. Is that high upload variability to anyone else ? My download speeds seem to be around always less than 1Mbp/s and lower , like around 100Kbp/s at any given moment
Normal? Every network can be different. To determine your "normal" just monitor it for a few days or longer. And your "normal" will likely change over the course of a day.
Just do not get hung up on this topic unless you feel there is something wrong.
Better yet, do not look at the logs or upload/download. Then you will not worry about things you have no control over.
I definitely don't have 10-40GB unknown uploads per day.
