IPV6 DUID
Shonk
Every reboot of my ac88u im getting a new /56
i have been told that i wont usually get a new prefix unless the following happens
* Your DHCPv6 client changes DUID, which we've heard pfsense and others do
* Your DHCPv6 client sends a RELEASE, explicitly telling the DHCPv6 server to relinquish your prefix.
anyone know of a simple way to stop me getting a new range every time i reboot
i dont want to have to pull the power to stop me getting a new range
pfSense does when keeping /tmp and /var/run in RAM - if kept on disk, the problem doesn't occur...
Long and complicated story there...
Asus builds the duid out of the MAC address, so it shouldn't be changing. It's probably issuing a release at shutdown time because it seems like the proper thing to do.
Your ISP should ensure that DUIDs remain tied to allocated prefixes instead, the same way most cable providers that I know will do with IPv4, tieing it to your MAC.
heh you a fellow sky customer?
I have the same issues.
Thats the way its being done in the uk sadly
the isp router doesnt have this problem as it doesnt issue a release on reboot
Sky in the uk have some 6 million subscribers and this is the way they are doing it and are pig headed with these type of things
would be really nice if we had a way of not doing a release on reboot
or if you could point me to where i should look for the release in the source
Fixed
vi /home/shonk/asuswrt-merlin/release/src-rt-7.14.114.x/src/router/rc/udhcpc.c
Hard Code dhcp option 60 & 61 (not needed with the latest commit but did it out of habit)
ipv6 Don't send a RELEASE when stopping
Confirmation
shonk nice, how do you compile asuswrt? I have linux knowledge, but not with compiling embedded systems.
Apologies - having a hard time seeing the screen shots (color vision differences, I just have a really hard time seeing it).
Can you post a diff?
add
"-k",
edit
int index = 7;
to
int index = 8;
Before
start_dhcp6c(void)
  char *wan_ifname = (char *) get_wan6face();
  char *dhcp6c_argv[] = { "odhcp6c",
  "-df",
  "-R",
  "-s", "/tmp/dhcp6c",
  "-N", "try",
  NULL, NULL,  /* -c duid */
  NULL, NULL,  /* -FP len:iaidhex */
  NULL, NULL,  /* -rdns -rdomain */
  NULL, NULL,  /* -rsolmaxrt -r infmaxrt */
  NULL,  /* -v */
  NULL,  /* interface */
  NULL };
  int index = 7;
  struct duid duid;
  char duid_arg[sizeof(duid)*2+1];
  char prefix_arg[sizeof("128:xxxxxxxx")];
  int service, i;
After
start_dhcp6c(void)
  "-df",
  "-R",
  "-N", "try",
  "-k",
  NULL,  /* -v */
  NULL };
  int index = 8;
  struct duid duid;
  int service, i;
nice that odhcpc already provided the option.....I had to to code a new option for wide-dhcpv6 that's used in my fork :)
Usage: odhcp6c [options] <interface>
Feature options:
  -S <time>  Wait at least <time> sec for a DHCP-server (0)
  -N <mode>  Mode for requesting addresses [try|force|none]
  -P <length>  Request IPv6-Prefix (0 = auto)
  -F  Force IPv6-Prefix
  -V <class>  Set vendor-class option (base-16 encoded)
  -u <user-class> Set user-class option string
  -c <clientid>  Override client-ID (base-16 encoded 16-bit type + value)
  -i <iface-id>  Use a custom interface identifier for RA handling
  -r <options>  Options to be requested (comma-separated)
  -R  Do not request any options except those specified with -r
  -s <script>  Status update script (/usr/sbin/odhcp6c-update)
  -a  Don't send Accept Reconfigure option
  -f  Don't send Client FQDN option
  -k  Don't send a RELEASE when stopping
  -t <seconds>  Maximum timeout for DHCPv6-SOLICIT (120)
  -m <seconds>  Minimum time between accepting updates (30)
Invocation options:
  -p <pidfile>  Set pidfile (/var/run/odhcp6c.pid)
  -d  Daemonize
  -e  Write logmessages to stderr
  -v  Increase logging verbosity
  -h  Show this help
A few people on the sky forum asked me to do a build for them with the fix
if anyone wants it im uploading them as they compile
RT-AC5300 Done
RT-AC88U Done
RT-AC3100 Done
RT-AC3200 Done
RT-AC87U Fails to Compile atm
RT-AC68U Done
RT-AC56U Done
RT-AC66U Fails to Compile atm
RT-N66U Fails to Compile atm
http://pc.cd/G0octalK
What name did you use for the nvram setting? If it fits with the existing settings that I use (since we have different IPv6 architectures), I might reuse the same setting if I end up adding the option on the webui.
ipv6_dhcp6c_release
great shonk, a guy on kitz forums wants it for the ac87 I think.
Seems I am the only sky user on an ac68 tho :p
Im getting another problem now
in ipv6 everything looks normal on router power up
i have kept my /56 and all looks good
in system log ipv6 all looks normal apart from the wan ipv6 gateway is blank
ps in telnet shows
odhcp6c -df -R -s /tmp/dhcp6c -N try -k -c 00030001000000000000 -FP 0:56108 -r23 -r24 -r82 -r83 eth0
if i do a kill -9 pid
then
all is fine and wan ipv6 gateway gets populated
anyone have any idea's
