IPV6 vs Nat Acceleration - AC66
mogulman
Anyone know if any recent firmware has fixed the issue with IPV6 and Nat Acceleration being enabled on an AC66 router, causing the router to intermittently reboot?
I know the NAT Acceleration code is closed, so unless they changed a version on that, probably not.
Anyone know if the AC87 has the same issue with the router rebooting if you enable NAT acceleration and IPV6?
This is in relation to the Asus Merlin firmware btw.
Not sure if pure Asus firmware has the same issue.
