Is there a WiFi scanner that shows bandwidth
Channel bandwidth, i.e. 20/40/80 MHz?
What apps have you tried?
Yes I mean channel bandwidth 20/40/80/160. I downloaded a couple free apps like "WiFi analyzer" from the play store(android) but none show the bandwidth as far as I can see. Can you suggest an app that does?
I hate downloading a bunch of free apps to my phone just to try them out because they don't always uninstall cleanly. I tried a couple more in the list in the playstore and found one that shows the bandwidth. The one I found is called WiFi analyzer made by Webprovider
I've come to rely on WiFiman from Ubiquiti - tend to trust them more than most other devs. It'll show you Speed, Channel Width, and Distance to each node. It's audible report of signal strength and Link History features are useful in exploring heat maps and roaming hand-offs. Requires location be enabled, but they all should because Google.
Great tool as long as it worked...... However it has stopped working now. Re-install doesn't help. I get an icon in the task bar - that's all. No window is created. The only thing possible to do is to close the icon.
Cleared cache and rebooted. Then tried to installed again.
Same result.....
Searched for all files with winfi in the file name and found a lot of them. Deleted all of them (both directories and files). Re-started and re-installed.
This time a large black window opened up. Something seems to be loading but nothing happens.
After some time I got an error message:
Nothing more. I'm clueless........
However, on the Helge Keck home page, there is a note telling us that WinFi is not available in Microsoft Store and that it needs to be downloaded from the Helge Keck home page.
Maybe something was changed in a recent Microsoft update that stopped WinFi to work correctly?
Same result.....
It is possible and at that time I also did blame my issues to Microsoft updates but wasn’t able to pinpoint which one. I should mention that I went for a while this program (don’t remember exactly how long) and then one day when I tried to install it again from the developer’s website. It downloaded without any issues and it is currently working just fine.
I use WiFi Explorer and it shows the info you need. They have a Pro version and a free version. The free version works great for my needs.
Edit: WiFi Explorer Lite is the free version.
Edit #2: I just realized this is a Mac only program so sorry if you don't use Mac.
Yep, I agree. I also use WiFi Explorer on my Mac.
