dhendodong
Is there an asus router that has a 1gb sfp/sfp+ port?
i read the fine print and it said the sfp+ port can only negotiate at 10gbps what im plugging in only supports 1gbYes, but it's not cheap, as it's really a 10Gbps port, but it can do 1Gbps as well.
RT-AX89X|WiFi Routers|ASUS Global
ASUS gaming routers provide the very best gaming experience, with an arsenal of features and tools designed to improve online gaming performance and give you the competitive edge you need to win.www.asus.com
Get yourself media converter, where one port is Sfp and other one ethernet they negotiate on 1 Gbps and then you can use normal router with it.i read the fine print and it said the sfp+ port can only negotiate at 10gbps what im plugging in only supports 1gb![]()
Where did you see that?i read the fine print and it said the sfp+ port can only negotiate at 10gbps what im plugging in only supports 1gb![]()
Up to means that's the highest supported speed, so Gigabit should also work.This port is for SPF+ connection with data transmission speed up to 10Gbit/s
The manual says:
There's no other information I can find about it.
Well that kinda defeats my use-case i want to use an ONT module so i can directly plug my isp fibr to my network and get rid of their provided ONT/Modem.Get yourself media converter, where one port is Sfp and other one ethernet they negotiate on 1 Gbps and then you can use normal router with it.
Something like this
https://www.amazon.ca/dp/B003CFATL0/?tag=smallncom-20
I'm guessing you're referring to this: https://www.asus.com/support/FAQ/1044066
I note that the QVL list it directs you to look at doesn't exist.
I think they might be suggesting that you should only use an SFP+ module (aka 10Gb) but AFAIK that shouldn't mean you can't use a 2.5Gb SFP+ module.
Hmm. Yes it appears you are correct.As per my google search kindly correct me if i am wrong, 10GB sfp cant auto negotiate, when its 10gb you can only plug 10gb, unless you have a module/media converter.
You'd think they'd put that in the manual...
And companies are supposed to put as many hurdles in the way as possible to get correct information?It's always 'up to'. Otherwise, they'd have other issues.
A buyer is supposed to be (i.e. expected) to be fully versed in what they're buying, and why.
really? wow thanks for this very helpful comment i guess ill proceed to buy this, i was planning to build a pfsense box instead with sfp pcie again thank you, can you also attach a screenshot of how does it look in the UI if a sfp is attached to the sfp+ and can we manually change the negotiation speed? and just to confirm can i use the sfp+ as WAN? and can the 10GB LANPORT negotiate at 2.5GB? or just 10GB? (my homelab is 2.5gbe thats why this is very important)I was using my AX89X with a 1GB SFP module (D-Link DEM-310GT to be precise) connected to a D-Link switch with the same SFP module on the other end, it worked fine.
I just plugged in the SFP and it just worked, but I can't get a screenshot of it because while it used to be running my network, the AX89X is now just an AiMesh node out in my garage connected via normal ethernet. It was too unstable and I swapped it out for an RT-AX86U.really? wow thanks for this very helpful comment i guess ill proceed to buy this, i was planning to build a pfsense box instead with sfp pcie again thank you, can you also attach a screenshot of how does it look in the UI if a sfp is attached to the sfp+ and can we manually change the negotiation speed? and just to confirm can i use the sfp+ as WAN? and can the 10GB LANPORT negotiate at 2.5GB? or just 10GB? (my homelab is 2.5gbe thats why this is very important)
Regards,
How was it "unstable"?I just plugged in the SFP and it just worked, but I can't get a screenshot of it because while it used to be running my network, the AX89X is now just an AiMesh node out in my garage connected via normal ethernet. It was too unstable and I swapped it out for an RT-AX86U.
Well that kinda defeats my use-case i want to use an ONT module so i can directly plug my isp fibr to my network and get rid of their provided ONT/Modem.You may want to look for a fiber to ethernet converter.
Is there a particular reason that you want to get rid of your ISP's CPE? Sometimes the CPE will do a VLAN encapsulation so when you put the CPE in bridge mode the PPPoE on your router would work.Well that kinda defeats my use-case i want to use an ONT module so i can directly plug my isp fibr to my network and get rid of their provided ONT/Modem.
Welcome To SNBForums
