issue on 384.12 and above, VPN server fails start
Jumpstarter
periodically when my router reboots on scheduled reboots, a VPN server may fail to start, might be vpn 1 or vpn2 I am trying to figure out what could be causing this behavior. I see no errors in the log, it looks to be that it is just failing to have enough time to start.
any suggestions?
any suggestions?
I suggest you reset your OpenVPN Server settings by pressing the "Default" button, and re-configure your few specific OpenVPN settings again. I have a slightly different problem on 384.13 alpha 2 it works for me ... so thought might be something you want to try. All the best :)
Thank you for your suggestion, I went through this process last week of resetting everything back to default, and it turns out a week later the issue starts happening again.
