Issue with Entware-ng: read only file system after reboot
sdajkdcbhzb
Happen after reboot on RT-AC68P
from mount command:
rootfs on / type rootfs (rw)
/dev/root on / type squashfs (ro,relatime)
devtmpfs on /dev type devtmpfs (rw,relatime,size=127752k,nr_inodes=31938,mode=755)
proc on /proc type proc (rw,relatime)
tmpfs on /tmp type tmpfs (rw,relatime)
sysfs on /sys type sysfs (rw,relatime)
devpts on /dev/pts type devpts (rw,relatime,mode=600)
/dev/mtdblock4 on /jffs type jffs2 (rw,noatime)
usbfs on /proc/bus/usb type usbfs (rw,relatime)
/dev/sda1 on /tmp/mnt/sda1 type ext2 (ro,relatime,user_xattr)
/dev/sda1 on /www type ext2 (ro,nodev,relatime,user_xattr)
had the same issue after a while with an old usb stick. i changed the stick to an other brand and now it's working since weeks without any problem.
OR, maybe connect the device with USB Y-adapter? One end plugs into the router USB port. Other end plugs into a 5V DC 2A USB power adapter. It's possible you're drawing too much power through the router's USB port.
