Solved Issue with iptables logging in Kamoj addon 5.4b6
R. Gerrits
Running addon version 5.4b6 and have some issues with iptables logs.
After reboot, I do get iptables log messages in /var/log/log-message (messages from aegis blocking some connections).
After some time, those iptables log messages are no longer logged there.
(this time latest message was 9984:[ 9983.118994] [aegis] IN=brwan....)
dmesg also does not work. (shows nothing)
If I disable "Save the system logs to USB. (or /opt/kamoj/logs if no USB detected)" then dmesg starts working again.
dmesg then also shows the latest iptables log messages.
But these iptables log messages are still not appended to /var/log/log-message
(that only continues to show messages from DHCP or admin login)
Any ideas what could cause this??
EDIT:
I do see that with "Save the system logs to USB" dmesg logs indeed are on /mnt/sda1/system_logs/dmesg.txt.
But I think aegis is only looking at /var/log/log-message
I have the same issue, the Aegis logs stops being output to /var/log/log-message after uptime 9989 for me.
The aegis logs are still coming in the dmesg log though.
EDIT:
  • Like
Reactions: KW.
Ok, found out how to get the Aegis logs back...
Don't know what kind of bug it is. Probably we need @Voxel to solve that riddle.
 echo "N" >/sys/module/printk/parameters/time
I also set this but don't know if it matters:
dmesg -n 8
I set this to Y in my add-on to get timestamps on dmesg events.
