It's finally happened!
:) im currently using merlins build 3.0.0.4.372.32 beta1 but i cant wait to upgrade to this new one, sucks ima have to break my uptime though
Now i am worried about upgrading since 372.32 latest beta works great. Not sure if i should mess with a good thing.
Seems that if it works for you don't touch it.
Usually best to upgrade to a final release when you are currently running a beta.
In this particular case tho, Beta 3 was only released as beta because it was a temporary release while waiting for the 374 code. It didn't get the same amount of testing I usually do before releasing a new stable version.
I not saying anything bad about your work, its been great (thanks), its just the wireless drivers seem to be an issue.
I felt good about installing Beta 3 because the wireless drivers are the same as the non beta release. Its the next version based on 374 that i am worried about.
Its all working great for me now, i just want to keep it that way.
Thanks for all your hard work.
