Beta Asuswrt-Merlin 3006.102.5 Beta is now available
LOL. I do not monitor this forum daily. My issue is today is the only day i have enough free time to install and reconfigure a new release that's all. Like i said just asking. not the end of the world.
Even better use case to install MerlinAU and just do it at night while your sleeping 😴 #ShamelessSelfPromo
Okay well I figured you were getting impatient of checking for updates thats why I suggested. But even better reason if it's time related! 😀
No thanks i don't use add on's not interested, just need a smooth running router nothing more nothing less.
To each their own!
I'll be sleeping when mine auto-updates, time constraints are a thing of the past my friend!
No worries , then I would tailer my recommendation to just patiently keep waiting for the beta cycles to end
Update a while ago and everything working just fine.
I'm trying to generate "--tls-crypt-v2" key but seems program missing command to genearet that.
# Generate per-client tls-crypt-v2 key with metadata = client_name
openvpn --tls-crypt-v2-genkey "$TLS_CRYPT_V2_CLIENT" \
--server "$TLS_CRYPT_V2_SERVER" --metadata "$client_name"
Get this code:
Options error: Unrecognized option or missing or extra parameter(s) in [CMD-LINE]:1: tls-crypt-v2-genkey (2.6.14)
Is it missing in this builds? and if then can that be included in next relese? openvpn 2.6.14 support it.
Everything else I can do manually.
@RMerlin
That parameter does not exist according to the OpenVPN 2.6 manpage:
The proper command is:
--genkey tls-crypt-v2-server
I have modified my string to this:
openvpn --genkey tls-crypt-v2-server "$TLS_CRYPT_V2_CLIENT" server "$TLS_CRYPT_V2_SERVER" [metadata] "$client_name"
But get: /jffs/configs/key_gen4.sh: line 160: --genkey: not found
EDIT: got it to working now, changed syntax to:
openvpn --tls-crypt-v2 "$TLS_CRYPT_V2_SERVER" --genkey tls-crypt-v2-client "$TLS_CRYPT_V2_CLIENT"
