Layout #10 (Router - Switches - Cable Modem)
tipstir
http://www.mediafire.com/imgbnc.php/c8e2cbc4e29e45ecdafca59574dd929b5g.jpg
top to bottom
1. DIR-655 wireless Xtreme N Router
2. EZXS88W 100mbps 8-port switch (replacing with 16-port)
3. TEG-S80TXE 1000mbps 8-port switch
4. Cable Modem 43mbps down max.
Remove all 7x Netgear switches FS 100 and GS 1000 just crap. I had the Linksys 8-port from prior usage. I am getting 16-port and connect everything directly into it that is not a Gig. That means all Wireless Access Points 3x, 7x Wired Network Media Players and 1x Wired Print Server comes out to be 11 ports for now for 100mbps side. Also most finish re-wiring the enough house. Gig nodes are completed. So far gone are the downgrade issues, Network Stream Media has issues where FF/RR and power off would loop. That problem is gone. Now everything runs smooth, but a lot of wires.
