Looking for a new stylish WHITE AX Node for my AX86U
sl4fko
So...
Until now I had a AC86U main router and an AC68U WHITE router as an AIMESH node in my living room (ETH backhaul).
I plan on buying a new AX86U router but also want to switch my node with a new AX one. Color MUST be white and inconspicuous. Merlin firmware is not necessary for a node.
Which one would you guys prefer in combination with AX86U? ISP connection is 500/500 with 1Gbps in a near future.
XD4
XD6
XT8
or something else...
Thanks in advance!
Provided you don't need loads of speed on the node, then the RP-AX56 might be the easiest choice to set up. I actually went with an XD4 originally as it's so inconspicuous - identical specs, just it was a pain to connect to the GT-AX6000, and seemed to lose its settings after about a day.
*Considering putting the RP-AX56 onto a "timed" smart outlet as it only seems to come into play at weekends and public holidays when surrounding networks are busier!
Hm, interesting choice. However, I think I need a bit more "power" on the node. Few smartphones, Firestick 4K and two laptops are (will be) connected to the node...
