Looking for a replacement for RT-N66U
yokuyuki
It seems like my RT-N66U is on the way out so I'm looking for a replacement for it. I currently have a 300/20 internet connection with 3 wired devices and about 14 wireless devices (currently all <= WiFi 5) connected to it including various IoT devices in a medium-sized apartment in a dense city although I'm looking to get a house at some point.
Some of the features that I use:
  • DDNS
  • DoT
  • Using the guest SSID as a separate VLAN to isolate IoT devices from the intranet
  • SSH access to tunnel connections
  • Port forwarding
  • Manually assigned IP in DHCP
I am security conscious so frequent firmware updates to keep it secure is important to me.
I've been looking at either another ASUS router since I'm familiar with the interface, but I've also been taking a look at the UDM.
  • DDNS
  • DoT
  • Port forwarding
What is your budget, if I may suggest rt-ac86u is very good bang for the performance while at same time get frequent updates.
If the RT-AX88U is in your budget, that is the one to get today. :)
But don't forget to check your original thread for a possible way to get your current router stable again. :)
