A
ajainy
Guest
My home setup is something like this..
10/100 linksys router
2 laptop with wireless 802.11g (not n). They both r being used over the wireless network
Planning to buy PS3.
I need a NAS type solution for all my multimedia files. So that both laptops (windows vista & windows XP) can share it.. Also planning to use with itunes.
So basically, i am looking for multimedia NAS type solution w/o buying new 1000mb/s router. (if i am going to use 802.11g, then it doesn't make difference, does it?)
So far, i have looked at buffalo linkstations or simpletech.
What you guys recommend? My budget is around 150 bucks including HD (even 250 gb is more than enough).
And i don't think, i need to go for solution like D-Link DNS 323 or Zyxel NSA-220. As i don';t need raid & my budget.
But still your recommendations, and hints to help me decide, i will really appreciate it.
There is something like some media certified product for streaming. does it make difference, if i have stream media to PS3 or my laptop?
