scope_creep
setup is asus rt-n66u with vigor 120 adsl modem.
Behaviour seems to be that connection is dropping every day at around 4pm.
I've attached the syslog. I've also put a shielded, I think S/FTP cable between the modem and router, which was one solution on the web.
Taking yesterday as an example, the log reports
Mar 7 14:16:27 WAN Connection: Fail to connect with some issues.
Mar 7 14:16:27 stop_nat_rules: apply the redirect_rules!
Mar 7 14:16:28 pppd[342]: Connection terminated.
Mar 7 14:16:28 pppd[342]: Modem hangup
Mar 7 14:16:39 pppd[342]: Connected to 00:50:7f:f3:69:96 via interface eth0
Mar 7 14:16:39 pppd[342]: Connect: ppp0 <--> eth0
Mar 7 14:16:40 pppd[342]: CHAP authentication succeeded
Mar 7 14:16:40 pppd[342]: peer from calling number 00:50:7F:F3:69:96 authorized
Mar 7 14:16:40 pppd[342]: local IP address 81.130.130.150
Mar 7 14:16:40 pppd[342]: remote IP address 81.130.224.1
Mar 7 14:16:40 pppd[342]: primary DNS address 194.72.9.38
Mar 7 14:16:40 pppd[342]: secondary DNS address 62.6.40.162
Mar 7 14:16:40 start_nat_rules: apply the nat_rules(/tmp/nat_rules_ppp0_eth0)!
Mar 7 14:16:40 rc_service: ip-up 17186:notify_rc stop_upnp
Mar 7 14:16:40 miniupnpd[11347]: received signal 15, good-bye
Mar 7 14:16:40 rc_service: ip-up 17186:notify_rc start_upnp
Mar 7 14:16:40 miniupnpd[17215]: HTTP listening on port 46407
Mar 7 14:16:40 miniupnpd[17215]: Listening for NAT-PMP traffic on port 5351
Mar 7 14:16:43 WAN Connection: WAN was restored.
At Mar 7 14:16:28 the modem drop the wan connection. Is that normal behaviour? It was working fine for a 1.5 years, until that big BT outage last week, then regular drop outs every afternoon. It is providing connectivity in a restaurant, so I set the DHCP lease down to 10800, so as to get back the lease IP address for customers who only stay on average 2 hours. I don't think it has a bearing on it. I've had one draytek vigor modem failing on me before, but not for 4 years. The router has a static IP, obviously setup on the modem.
3 years ago, we had a similar problem seemingly caused by a WAN dhcp problem. We put in a static IP and changed the dns to point to opendns and google. And it seemed to work fine.
Bob.
Bob.
