MTU (PPoE) setting not working
  • Thread starter Thread starter Deleted member 80734
  • Start date Start date
D
Guest
Hello,
I have a fiber connection from dutch provider KPN. I tried to setup my Asus AX88U via PPoE whit a MTU 1500 (rfc4638). i have Merlin 386.5 installed. After i change the value of MTU seize under PPoE settings, and did a test on my laptop
ping google.com –f –l 1492 i noticed that the MTU is still 1492, instead of 1500. Is this a known issue or did i something wrong?
I see allot of these in my logs:
Mar 14 20:54:11 start_wan_if(): Error setting MTU on eth0 to 1500
Mar 14 20:54:11 start_wan_if(): Error setting MTU on vlan6 to 1500
I did some tests. first one is MTU 1472 + 28= 1500
Pinging yahoo.com [74.6.231.20] with 1472 bytes of data:
Reply from 192.168.50.1: Packet needs to be fragmented but DF set.
Ping statistics for 74.6.231.20:
Packets: Sent = 4, Received = 1, Lost = 3 (75% loss)
Looks that his one is correct. Here is the MTU 1492
Pinging yahoo.com [74.6.231.20] with 1464 bytes of data:
Reply from 74.6.231.20: bytes=1464 time=120ms TTL=48
Reply from 74.6.231.20: bytes=1464 time=121ms TTL=48
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss)
I also tried some older builds, but same results. The only way to get a MTU of 1500 is to put back the modem from my provider and setup the WAN type connection to automatic ip.
