hi all My Asus 87u is very very hot when i touch it on the top of it... skould it be really hot that way ?
tthe temps are on that file.. im not sure is that normal ?
You are almost reaching the QTN Chip (5GHZ) max temperature (75º) , bad seated heatsinks/heatpads and once again BAD quality control from ASUS![]()
what the best way to lower temp it right beside me
just putted my asus ovr top of a book
Don't think so, 2.4GHZ radio temperature seems perfectly fine compared to the other two (5GHZ radio and CPU)
Active cooling its non-sense on any router, they shouldnt reach those temperatures out of the box.
I've seen the same scenario with my RT-AC68U and i have it working now with less 20º after reseat heatpads/heatsinks and i was forced to loose warranty because of it (i open it), ASUS should make better they're "home work" thats what it is, BAD QUALITY CONTROL.
yesDedicated 24h/24H AC?
That will result in good temperatures but quite expensive monthly.
Welcome To SNBForums
